lnarayanan_123
PS AXI (S_AXI_HP1 ) Slave Port HP1 access via PL Master ( custom design) having read write mismatches
Hi All,
I have developed a Custom master to access DDR3 Connected to PS . DDR3 device is 16bits wide and i have two devices connected to it. So the AXI Bus Width is configured as 32bits.
In the Address editor of Block design assigned address is 0x0_0000_1000_0000 --> 0x0_0000_1FFFF_FFFF.
DDR is accessed by software for booting purpose only.
AxSize = 2  [ 4 Bytes = 32bits in a beat ]
AxBurst=1   [ INCR]
AxLen = 7   [ Length = 8 ]
Write Transaction
Read Transaction
If the waveform is not clear i am putting in a tabular form as below:-
WRITE
READ
0000 A5A5
0003 FFFF
0001 5A5A
0003 FFFF
0002 A5A5
0003 FFFF
0003 5A5A
0003 FFFF
0004 A5A5
0007 FFFF
0005 5A5A
0007 FFFF
0006 A5A5
0007 FFFF
0007 5A5A
0007 FFFF
Is there anything i am missing in the AXI protocol Master design to do any write or read transactions with respect to the DDR Interface access.
Tags (3)
katsuki
Hi @lnarayanan_123
It is difficult to develop the AXI protocol from scratch.
I recommend that you use the Vivado Package IP Wizard to create a simple AXI master IP and start with this IP as a starting point.
UG1118 Vivado User Guide - Creating and Packaging Custom IP
The following Blog and Forum are also good references.
AXI Tutorials
AXI Basics Series
Thank you.
Don’t forget to reply, kudo, and accept as solution. If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
