PS I2C on PL side
HI,
I am using ZCU102.
Am able to access EEPROM on PS I2C device on MIO interface.
When we are enabling the EMIO on the same I2C device, we don't see any transitions on SCL or SDA.
Do we required any configuration to enable to EMIO pins.
P Dasarath
Re: PS I2C on PL side
Do you have pull ups on these lines?
Yes, I enabled the pullups
May i know which version are you using? Can you please upload your project so that will verify and address you.
Venu
it's sdk issue and it is resolved.
Thank you
