PS USB - external 2TB hard disk support
In one of our design, we want to include the PS USB in host mode to connect an external Hard disk of 2TB size.
So I was wondering whether the PS USB will support the large size?
Has anyone tested this interface ? Please let me know. Thanks in advaace.
Thanks & Regards,
Nanjunda M
Re: PS USB - external 2TB hard disk support
Hi @nanjundams.
it will support, the size limition only depends on what file system you are using it,
like fat32 only allows 4 GB max file size, ext32 allows 2TB i guess.
Not verified the same as far as i know.
Thanks & Regards
Aravind
Hi Aravind,
Does it support NTFS file format? Since most of the Hard-disks come in the NTFS format.
Thanks & Regards,
Nanjunda M
Mentor
Mentor
Hi @nanjundams.
If you use the following fuse-ntfs-3g from userspace, you can mount NTFS partition.
# Project
https://www.tuxera.com/community/open-source-ntfs-3g/
# Yocto recipe
https://github.com/openembedded/meta-openembedded/blob/master/meta-filesystems/recipes-filesystems/ntfs-3g-ntfsprogs/ntfs-3g-ntfsprogs_2017.3.23.bb
Best regards,
