ali-dn
PS doesn't sense my interrupt
Hi all.
I am using 3 interrupts that they are coming from a concat IP from PL.
By using ILA, I can see interrupt is triggering but CPU doesn't sense it.
ali-dn
Finally, I found the answer by searching on the internet.
I must add 1 line code for each of my interrupts.
XScuGic_SetPriorityTriggerType(&InterruptController, XPAR_FABRIC_MY_INT ,0x00 , 0x3 );
you must see that function declaration and put your correct values in arguments.
ali-dn
