PS freeze when memory access from MIG fail
I encounter a problem with a design based on Zynq and MIG controlling DDR3.
The normal behaviour of my tester is doing well : calibration of the MIG and access to DDR3 is ok.
But if i unpower the DDR3 after MIG calibration, and try to access to the memory, all my PS freezes.
Do you know if i can handle an AXI timout to make my design mort robust?
Hi pierrekhlr
I recommend to use watch-dog-timer to escape dead lock.
Thank you
Best regards
Hi watari,
Are you talking about Zynq SoC's private watchdog ?
I was thinking about the possibility of devolpping an additionnal IP to handle memory accesses in case of MIG or AXI bus crash.
Thank you
