bhavinlapasia
Picozed FMC carrier USB not detected
I am using Picozed SoM, Picozed FMC carrier card Gen2 for my testing. I am using pre-built images developed by Avnet for 2015.4 version and booting the PS. By default, the scheme of carrier board says that USB is connected in HOST mode. When I am connecting a pendrive on the USB connector, it is showing the following messages.
root@pz_7030_2015_4:~# usb 1-1: new high-speed USB device number 6 using ci_hdrc
usb 1-1: device descriptor read/64, error -71
usb 1-1: new high-speed USB device number 7 using ci_hdrc
usb 1-1: new high-speed USB device number 8 using ci_hdrc
usb 1-1: device not accepting address 8, error -71
usb 1-1: new high-speed USB device number 9 using ci_hdrc
usb 1-1: device not accepting address 9, error -71
usb usb1-port1: unable to enumerate USB device
When I do lsusb, it shows this even if no USB is connected
root@pz_7030_2015_4:~# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg | grep usb O/P:
root@pz_7030_2015_4:~# dmesg | grep usb
[    0.431011] usbcore: registered new interface driver usbfs
[    0.435138] usbcore: registered new interface driver hub
[    0.439196] usbcore: registered new device driver usb
[    1.424207] usbcore: registered new interface driver usb-storage
[    1.429199] e0002000.usb supply vbus not found, using dummy regulator
[    1.619083] usbcore: registered new interface driver usbhid
[    1.619086] usbhid: USB HID core driver
[    1.792618] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[    2.042636] usb 1-1: new high-speed USB device number 3 using ci_hdrc
[    2.416043] usb 1-1: device descriptor read/all, error -71
[    2.532557] usb 1-1: new high-speed USB device number 4 using ci_hdrc
[    2.972486] usb 1-1: device not accepting address 4, error -71
[    3.092578] usb 1-1: new high-speed USB device number 5 using ci_hdrc
[    3.512792] usb 1-1: device not accepting address 5, error -71
[    3.522442] usb usb1-port1: unable to enumerate USB device
[  201.152509] usb 1-1: new high-speed USB device number 6 using ci_hdrc
[  201.292496] usb 1-1: device descriptor read/64, error -71
[  201.532494] usb 1-1: device descriptor read/64, error -71
[  201.762498] usb 1-1: new high-speed USB device number 7 using ci_hdrc
[  201.892495] usb 1-1: device descriptor read/64, error -71
[  202.132506] usb 1-1: device descriptor read/64, error -71
[  202.362502] usb 1-1: new high-speed USB device number 8 using ci_hdrc
[  202.782477] usb 1-1: device not accepting address 8, error -71
[  202.902499] usb 1-1: new high-speed USB device number 9 using ci_hdrc
[  203.322477] usb 1-1: device not accepting address 9, error -71
[  203.326948] usb usb1-port1: unable to enumerate USB device
Is there any change needed to be done in pre-built device tree or any other file? Kindly help.
Bhavin
