Problem Writing to FSL
HI,
    I have successfully built an FSL module to write to the LEDS on my ML507 board; however, when I try to write to the FSL in software I am getting the following error:
/cygdrive/c/DOCUME~1/gq114c/LOCALS~1/Temp/ccdTVUck.s: Assembler messages:
/cygdrive/c/DOCUME~1/gq114c/LOCALS~1/Temp/ccdTVUck.s:21: Error: register expected, but saw 'rfslid'
/cygdrive/c/DOCUME~1/gq114c/LOCALS~1/Temp/ccdTVUck.s:21: Warning: ignoring operands: rfslid
make: *** [write_leds/executable.elf] Error 1
/cygdrive/c/DOCUME~1/gq114c/LOCALS~1/Temp/ccdTVUck.s: Assembler messages:/cygdrive/c/DOCUME~1/gq114c/LOCALS~1/Temp/ccdTVUck.s:21: Error: register expected, but saw 'rfslid'/cygdrive/c/DOCUME~1/gq114c/LOCALS~1/Temp/ccdTVUck.s:21: Warning: ignoring operands: rfslid make: *** [write_leds/executable.elf] Error 1
I have insured that all FSL interfaces are included in the mhs file and that everything is connected. What could the problem be? My c code is as follows to write to the fsl:
#include "stdio.h"
#include "xparameters.h"
#include "fsl.h"
int main(void)
unsigned int val = 0x55;
unsigned int id = 0;
nputfsl(val, id);
return 0;
Thanks for any input.
c
I found the problem just now, turns out you can't use a variable when writing to the fsl. It is expecting a literal. So by replacing the variable "id" in the c code with 0 (since I am using FSL device 0) it solved the problem.
c
c
