Surya_Charan
Problem in AXI4lite to APB address mapping
 Sir/Madam, I have been receiving a warning as APB slave is unmapped even though it is mapped in address editor. It is showing address disjoint. Moreover in APB to AXI4  converter it showing different address and is not allowing me to change it. I am not getting what vivado is trying to say with that warning. If I go ahead neglecting that warning then I am getting problem at Linux level as my host processor is not able to recognise my device. I attached a part of my block design, Address mapping and AX4lite to APB ridge properties. Sandlogic IP is my custom IP and I am trying to connect it to a host processor. Thanks in advance.
WARNING: [xilinx.com:ip:axi_apb_bridge:3.0-1] /axi_apb_bridge_0
APB_M Slave addresses {0x00041600 0x00000200} {0x00041800 0x00000800} {0x00042000 0x00002000} {0x00044000 0x00004000} {0x00048000 0x00008000} {0x00050000 0x00010000} {0x00060000 0x00020000} {0x00080000 0x00001000} {0x00081000 0x00000400} {0x00081400 0x00000200} are disjoint
WARNING: [xilinx.com:ip:axi_apb_bridge:3.0-17] /axi_apb_bridge_0
No of Slaves selected are 1 out of which 1 are un-mapped/disjoint.
Please map all the APB interfaces or re-configure the IP to match the number of slaves.
Tags (2)
