soto1980
Problem in access DDR from PL with AXI bus (HP0) when modification is made in Boot Flow ZYNQ.
Note:
Configuration HP0. Data Bus size: 32 bits
Configuration HP1. Data Bus size: 64 bits
Stage 1
Boot Flow:  BootROM -> FSBL (bitstream for the programmable logic) -> uBoot -> Image Linux
Everything works fine. Block A and B write in DDR3 and uC read from DDR3 correctly.
Stage 2
Boot Flow:  BootROM -> FSBL (WITHOUT bitstream for the programmable logic) -> uBoot -> bitstream for the programmable logic -> uBoot ->Image Linux
Note: uBoot know the position of bitstream inside flash
Block A (HP0) is not working fine, Block B work fine.
Analyzing behavior Block A with hardware manager seems to work fine. Signals on bus AXI are toggling correctly, but data is been writing in DDR3 have always zero value.
Stage 3
Keep data flow of stage 2:
Boot Flow:  BootROM -> FSBL (WITHOUT bitstream for the programmable logic) -> uBoot -> bitstream for the programmable logic -> uBoot ->Image Linux.
Change configuration HP0, data bus size move from 32 to 64 bits.
Stage 4
Return to data flow of stage 1:
Keep configuration HP of stage 3:
 Configuration HP0. Data Bus size: 64 bits
Analyzing behavior Block A with hardware manager seems to work fine. Signals on bus AXI are toggling correctly, but data is not been writing in DDR3.
Target: We need a HP configuration that support the both boot flow. Fsbl with and without bitstream. How can we achieve that?
Can you explain this strange behavior?
Thank in advance for help.
(Vivado version 2013.3)
smarell
Community Manager
Community Manager
Can you please share the logic debug screenshots during read/write transactions for test scenarios- 2/3&4?
I see the same effect when configuring the FPGA from uboot.
Its like HP ports get configured wrongly.
Is there any Answer to this?
Can you help on this topic?
