walkerata
Problem with PL generated edge sensitive interrupts in Vivado 2014.4
I'm trying to get the Zynq PS to appropriately acknowledge a user-generated (in the PL) edge-sensitive interrupt.
I have verified that my interrupt is being generated in the PL appropriately using the ILA (and an external scope). I have the sensitivity set within my custom IP appropriately. I am hooking the interrupt pin from my peripheral directly to the IRQ_F2P port on the Zynq PS.
The issue is that even though I have set the sensitivity of my interrupt to be "EDGE_RISING" in my peripheral, the PS seems to want to treat the interrupt sensitivity as though it is LEVEL_HIGH. When I click on the IRQ_F2P pin properties on the Zynq PS block, I can see that it has a config property set to "LEVEL_HIGH." I cannot change this property to EDGE_RISING, as it is read only.
The result is that (because this signal is active low) as soon as I enable the GIC, it triggers interrupts constantly even though no interrupts are occuring (the signal idles high). Vivado tells me that the Zynq GIC can only handle sensitivity settings of "LEVEL_HIGH" and "EDGE_RISING." How do I set the IRQ_F2P pin to be rising edge sensitive rather than LEVEL_HIGH sensitive?
walkerata
Okay, I solved my own problem.
XScuGic_SetPriorityTriggerType(Handle, Interrupt, 0x0, 0x3);
0x3 sets a rising edge triggered interrupt, 0x0 sets highest priority. System works now.
walkerata
I should further clarify, this interrupt is not being passed over an AXI interface. It is a one bit port on my peripheral connected directly to the IRQ_F2P port of the Zynq PS block.
Am I missing something? Is there some way to set the sensitivity of this interrupt in software when I register it? I've looked through all the examples and I can see some things regarding "trigger types" but I'm not quite sure what to make of that.
I'll do some more reading, but if anyone has any guidance it'd be much appreciated. :)
walkerata
muh_ali
@walkerata,
I also was looking for setting interrupt trigger type and found following functions:
To get the current interrupt priority and trigger type
* Gets the interrupt priority and trigger type for the specificd IRQ source.
* @param	BaseAddr is the device base address
* @param	Int_Id is the IRQ source number to modify
* @param	Priority is a pointer to the value of the priority of the IRQ
*		source. This is a return value.
* @param	Trigger is pointer to the value of the trigger of the IRQ
* @return	None.
* @note		This API has the similar functionality of XScuGic_GetPriority
*	        TriggerType() and should be used when there is no InstancePtr.
void XScuGic_GetPriTrigTypeByDistAddr(u32 DistBaseAddress, u32 Int_Id,
					u8 *Priority, u8 *Trigger)
To set the desired interrupt priority and trigger type
* Sets the interrupt priority and trigger type for the specificd IRQ source.
* @param	Priority is the new priority for the IRQ source. 0 is highest
* 			priority, 0xF8 (248) is lowest. There are 32 priority levels
*			supported with a step of 8. Hence the supported priorities are
*			0, 8, 16, 32, 40 ..., 248.
* @param	Trigger is the new trigger type for the IRQ source.
* Each bit pair describes the configuration for an INT_ID.
* SFI    Read Only    b10 always
* PPI    Read Only    depending on how the PPIs are configured.
*                    b01    Active HIGH level sensitive
*                    b11 Rising edge sensitive
* SPI                LSB is read only.
*                    b11 Rising edge sensitive/
* @return	None.
* @note		This API has the similar functionality of XScuGic_SetPriority
void XScuGic_SetPriTrigTypeByDistAddr(u32 DistBaseAddress, u32 Int_Id,
					u8 Priority, u8 Trigger)
kishorep
Hi ,
  I am facing same issue  in the linux environment, even after  calling below api after calling request_threaded_irq
irq_set_irq_type(61,IRQF_TRIGGER_RISING |IRQF_ONESHOT);
configured ISR is  not called, only when I set interrupt flag to  TRIGGER_LOW interrupt is triggered.
Any help ..?
Kishore P
