mohava
Problem with stopping the PL clock in zynq/Linux
Hi All,
I am woking on Zynq using Linux.
I want to stop/start the PL clock to implement clock gating.
I can change the PL clock frequency through software.
Bu when I use the Clock Throttle explained in UG858-Zynq TRM manual
The clock still running.
Also, I am using the Vivado-HLS to generate the IP and Vivado to create the SoC.
Any kind of help will be appreciated
Mohava
mohava
I found the solution and this is the code that worked for me, maybe it is useful for others
u32 ps_frequency_set(int divisor) {
int fd;
unsigned page_addr, page_offset;
void *ptr, *ptr_sta, *ptr_ddr;
unsigned page_size=sysconf(_SC_PAGESIZE);
/* Open /dev/mem file */
fd = open ("/dev/mem", O_RDWR);
if (fd < 1) {
perror("error 1\n");
return -1;
if (divisor > 63) {
printf("The PS frequncy divider cannot be divided by %d\n", divisor);
divisor = 62;
printf("The PS frequncy divider is set to the maximum which is 62\n");
if (divisor < 2) {
printf("The PS frequncy cannot divided by %d\n", divisor);
divisor = 2;
printf("The PS frequncy divider is set to default which is 2\n");
//enable SLCR_UNLOCK
unsigned slcr_unlock = 0xF8000008;
page_addr = (slcr_unlock & (~(page_size-1)));
page_offset = slcr_unlock - page_addr;
ptr = mmap(NULL, page_size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, page_addr);
*((int *)(ptr + page_offset)) = 0xDF0D;
unsigned long arm_clk_ctrl = 0xF8000120;
page_addr = (arm_clk_ctrl & (~(page_size-1)));
page_offset = arm_clk_ctrl - page_addr;
unsigned int arm_clk_ctrl_value = *((int *)(ptr + page_offset));
printf("original arm_clk_ctrl_value = 0x%08x\n", arm_clk_ctrl_value);
u32 divisor_MASK = 0xFFFFC0FF;
arm_clk_ctrl_value = arm_clk_ctrl_value&divisor_MASK;
divisor = divisor << 8;
arm_clk_ctrl_value = arm_clk_ctrl_value|divisor;
*((int *)(ptr + page_offset)) = arm_clk_ctrl_value;//0x00102000;
printf("updated arm_clk_ctrl_value = 0x%08x\n", arm_clk_ctrl_value);
close(fd);
return 0;
mohava
int fd;
if (fd < 1) {
return -1;
if (divisor > 63) {
divisor = 62;
if (divisor < 2) {
divisor = 2;
close(fd);
return 0;
mohava
PL enable and disable functions
u32 pl_disable_clock(int pl_clock) {
int fd;
unsigned long int fpga_thr_ctrl;
unsigned long int fpga_thr_cnt;
if (pl_clock == FPGA0_CLK) {
fpga_thr_ctrl = FPGA0_THR_CTRL;
fpga_thr_cnt = FPGA0_THR_CNT;
if (pl_clock == FPGA1_CLK) {
fpga_thr_ctrl = FPGA1_THR_CTRL;
fpga_thr_cnt = FPGA1_THR_CNT;
if (pl_clock == FPGA2_CLK) {
fpga_thr_ctrl = FPGA2_THR_CTRL;
fpga_thr_cnt = FPGA2_THR_CNT;
if (pl_clock == FPGA3_CLK) {
fpga_thr_ctrl = FPGA3_THR_CTRL;
fpga_thr_cnt = FPGA3_THR_CNT;
if (fd < 1) {
return -1;
//enable LVL_SHIFT_EN
unsigned lvl_shiftr_en = 0xF8000900;
page_addr = (lvl_shiftr_en & (~(page_size-1)));
page_offset = lvl_shiftr_en - page_addr;
*((int *)(ptr + page_offset)) = 0x0F;
//zynq_slcr_write 1-->FPGA0_THR_CNT_OFFSET
page_addr = (fpga_thr_cnt & (~(page_size-1)));
page_offset = fpga_thr_cnt - page_addr;
*((int *)(ptr + page_offset)) = 1;
//zynq_slcr_write 1-->FPGA0_THR_CTRL_OFFSET
page_addr = (fpga_thr_ctrl & (~(page_size-1)));
page_offset = fpga_thr_ctrl - page_addr;
close(fd);
return 0;
u32 pl_enable_clock(int pl_clock) {
int fd;
if (fd < 1) {
return -1;
//zynq_slcr_write 0-->FPGA0_THR_CNT_OFFSET
*((int *)(ptr + page_offset)) = 0;
//zynq_slcr_write 0-->FPGA0_THR_CTRL_OFFSET
close(fd);
return 0;
