Anonymous
Not applicable
Problems generating pcore from matlab with system generator
We are developing an application to detect uniform balls for a soccer robot. The application is implemented on the Virtex-4 Video Starter Kit from xilinx. As a template for this application we ere using the VSK_pcore_tutorial. When we generate a pcore with the system generator from matlab(v 10.1 with sp1) we get the following error:
"Error running xledkpostgen
Error using ==> feval
Error: <a href="error:C:\Xilinx\10.1\DSP_Tools\sysgen\plugins\compilation\EDK Export Tool\xledkpostgen.m,734,8">File: xledkpostgen.m Line: 734 Column: 8</a>
Arguments to IMPORT must either end with ".*"
or else specify a fully qualified class name: "com.xilinx.sysgen.netlister.EDKPCoreBuilder" fails this test."
According to question AR #30959 we switched to a PLB v4.6 output in the microblaze EDK Processor.  When we are trying to generate the pcore we get the same error.
(we created a PLB BUS in the system.xmp. The PLB BUS is connected to a FSL BUS by an plb2fsl_bridge)
The problem can be reproduced by the vid_go_sulotion.mdl.
Please help us to get a solution for this problem.
When will Service Pack 2 be available?
Kind regards,
Gerard
