Programming CMDA engine/addressing virtual/physical mapping
I've implemented an AXI CMDA engine in Vivado 2016.2 that I want to use to transfer a large amount of data from program space to a FIFO in PL in physical space. I'm using Xilinx SDK 2016.2 and running petaLinux.
From what I read, I need to use a function called: dma_alloc_coherent() to make sure I get a continuous block of memory in physical space and I need to use io_remap() to get the physical address from the virtual address. Is this correct or is there an easier/better way?
If this is so, where can I find these functions? I don't seem to be able to find them in the include directories.
Thanks!
Re: Programming CMDA engine/addressing virtual/physical mapping
@doug.rhodes Are you sure? AXI CDMA is mm-master to mm-slave. You mean AXI DMA?
It is an AXI Central Direct Memory Access block from the Vivado IP.
@doug.rhodes AXI CDMA does not have stream interfaces. It cannot connect to a FIFO.
