QSPI + NAND at once
hi,
is it possible to use QSPI and NAND flash at once.
In detail, I want to use QSPI for Booting and NAND-Flash for Linux-file-system storage. Is this possible?
I ask, because both flashes use separate chip-selects and the TRM is not clear about this
Tags (3)
No you can't use QSPI & NAND at the same time. Actually TRM [UG585 (v1.6.1) on page 50] says:
Static Memory Controller (SMC) Interface:Only one SMC memory interface can be used in a design. The SMC controller consumes many of the MIO pins and neither of the SMC memory interfaces can be routed to the EMIO. For example, if an 8-bit NAND Flash is implemented, then Quad-SPI, is not available ...
Not sure but  for your purpoae, I think SD card can be a good choice...
Thanks for clarification.
Then all the boards which mount a QSPI and a NAND-Flash are wasting memory. :-(
