Quad Spi interrupt enabling in Zynq Ultrascale
I have recently started to work in Zynq ulltrascale. I want to use QSPI0 peripheral in Zynq ultrascale board. It is connected to ARM. I want to know in which Zynq ultrascale register , at which bit I have to set the interrupt enable for QSPI. From which Xilinx datasheet can I get information regarding the register settings for QSPI in Zynq ultrascale in detail (with information regarding each bit position in register).
Thanks in advance
With Regards
Shalini
回复: Quad Spi interrupt enabling in Zynq Ultrascale
Hi sha@hys,
I think the document you needed is UG1085 Zynq UltraScale+ Device Technical Reference Manual.
And for easy start your application, you are recommended from the example design the BSP provided. It also provides the qspi example with interrupt.
Re: Quad Spi interrupt enabling in Zynq Ultrascale
Hello
Thanks for reply.i can see quad spi peripheral setting here.but I want to see gic register for zyncq ultrascale.where can I get that.? I think I have to set for qspi enabling in GIC registers.
Thanks in advance
With regards
Shalini
Hi sha@hys,
Please check the GQSPI_IER and GQSPI_ISR registers in UG1087 (Zynq ultrascale+ MPSoC Register reference manual).
https://www.xilinx.com/html_docs/registers/ug1087/ug1087-zynq-ultrascale-registers.html
Best Regards,
Srikanth
