Query- Video & imaging IP pack and Open CV
I have ordered Zynq-7000 Video and Imaging Kit needs clarification on the following points:
1- plz. tell the IP cores avalable from xilinx Video & imaging IP pack are in C,VHDL OR verilog.
2- Can the IP cores be ported on FPGA fabric or processing system or can be both.
3- if user needs a custom implemenattion of some video codec using OPEN CV libraries can it be ported on both Fabric and processing system or both.
4- whther the refrence design provided stores the video frame in DDR3, as no video encoder has been used in the design flow seen.
looking for ur kind reply.
1. These are the IPs in the Video and Image Processing pack: http://www.xilinx.com/products/intellectual-property/ef-di-vid-img-ip-pack.html. You can instantiate them in either VHDL or Verilog designs.
2. These particular IP are fabric-only.
3. Yes, the ARM will run standard OpenCV libs and Vivado HLS also supports OpenCV so it should be very easy to port.
4. I don't understand your question. Are you looking for an example design showing video encoder?
www.xilinx.com
thanks for ur reply....
1- plz clarify me : Can OpenCV libraries be executed/imlemented on FPGA fabric also.If yes HOW?
2- Does Vivado HLS provide OpenCV libraries.Plz. help me to track the path for the same.
3- do we have any small refrence design to understand/test OpenCV intergration with tool.
4- Do the OpenCV libraries provide video encoder API also.Can we locate them.
Looking for ur great help.
Plz, commant on this too:
Do the OpenCV libraries provide video encoder/Codec API also.
