xilinxcocuk
Questions to AXI DMA
Hello, I have a 12 Bit ADC. I want to write the incoming data to the Arty S7s DDR3. I am using a FIFO to buffer the data, the FIFO is connected to the AXI DMA IP.
I looked up the AXI DMA documentation and it says when not using "Scatter Gather Engine" a destination adress inside the DDR3 will be specified, where my ADC data is stored. I am not really sure where the destination adress is. But I think it should be 0x80000000?
Where can I see the destination adress (S2MM from AXI DMA to DDR3)?
Thank you!
Tags (3)
abouassi
Hi @xilinxcocuk,
First check how the DMA is programmed in Simple mode, by reading the "Programming Sequence > Direct register Mode" of PG021:
As you could see, the destination address should be set on S2MM_DA.
From Table 2-6, you can see the offset of the S2MM_DA, which is 0x48:
The S2MM_DA address will be the DMA base address + this offset.
From the screenshot you sent, the DMA base address is 0x41E0_0000:
So, S2MM_DA address is 0x41E0_0048.
Best regards,
Abdallah
