helplessguy
Read txt-file from FAT32 SD card barmetal
Hello everyone,
I am having a SD Card, that is connected to MIO 40-45 at PS of Zynq, speed: slow, pullup: disabled). I have the Zybo Z7-20 evaluation board.
On the SD-Card (FAT32) is a textfile test.txt and there are numbers inside, that I want to load to memory.
I was looking now the last weeks for solutions/examples, but I didn't find something helpful.
I am also not sure, that library is really helpful, and if there is some example code existing.
Is a reading with fopen/fclose and getc possible, or not?
be gladful about all answers!
savula
Hi @helplessguy ,
Please check the Xilffs polled mode example. This examples opens a file in SD card and Read/writes the data into the file.
https://github.com/Xilinx/embeddedsw/blob/master/lib/sw_services/xilffs/examples/xilffs_polled_example.c
Best Regards,
Srikanth
