Reading DDR from master peripheral
I want to read data from DDR from my master peripheral in a MicroBlaze system.
I sent a read request to DDR by modifying the USER_LOGIC.v file  generated by the XPS tool
I set  ip2bus_mstrd_req = 1;   ip2bus_mst_addr = address of DDR;   appropriate value for ip2bus_mst_be
I could not read anything   i am getting
                          bus2ip_mstrd_src_ready_n = 1
why is this happening i wonder
please someone help,  because of it all my project is stuck at this point
Voyager
Voyager
Re: Reading DDR from master peripheral
Reading and writing to DDR is a fairly complicated process.  The AXI protocol must be closely followed in order to achieve a successful transfer.
I find it much easier to use the AXI infrastructure to do it for me.  Take a look at using one of the DMAs (SG-DMA, VDMA,...).  A second option is the AXI DataMover (https://www.xilinx.com/support/documentation/ip_documentation/axi_datamover/v5_1/pg022_axi_datamover.pdf).
Ted Booth | Tech. Lead FPGA Design Engineer | DesignLinx Solutions
https://www.designlinxhs.com
