Reading e-fuse user register
I'm wondering if it is possible to read the e-fuse user registers from the PS. Preferably from linux, but a handover from U-boot or the FSBL could also work.
Maarten
Re: Reading e-fuse user register
TRM 4.7
F800_D000 eFuse
for some reason this address space is not explained..
ug470 config: FUSE_USER 32 bit accessible to fabric
very easy way would be to connect efuse_user primtiive to EMIO gpio input pins.. then it just readable without any software overhead
TRM 4.7
F800_D000 eFuse
