fiedel
Replacing AXI Interconnect IP with AXI SmartConnect IP?
I usually let Vivado do AXI connections automatically. I'm working on a project in which PS sends/receives data through AXIS data FIFO, and writes to a register file in PL through AXI-Lite. Vivado connected the IPs using both AXI Interconnect and AXI SmartConnect:
In which M00_AXI is AXI-Lite and connects to PL.
Address map:
I haven't run software yet but at least the block design passed validation without errors.
Since AXI SmartConnect is to replace AXI Interconnect, I manually changed the block design by removing AXI Interconnect and moving the connections to AXI SmartConnect. I got :
Let Vivado automatically assign addresses:
And it failed validation:
So my questions are:
- Is it reasonable to replace AXI Interconnect with AXI SmartConnect?
- How do I assign addresses for these blocks?
Thank you for suggestions.
Tags (2)
florentw
HI @fiedel
Yes this should be possible. With that said you are not forced to do it
I would say that this issue is coming because the address were assigned when you had the interconnect. I would suggest few different things:
  • In the block automation window, sometimes you can choose what type of interconnect you want vivado to instantiate. If you can select the smartconnect at this level
  • If possible replace the interconnect with the smartconnect before running the validation of the design
  • And i you are facing the error you have, maybe try to unmap the addresses in the address editor tab and assign them automatically again.
Florent
adem369
You should be careful when using smartconnect because it has some limitations. Refer PG247 page 7-8.
