Require Tutorial
 Is there any tutorial which explains the processing of creating and importing custom IP in XPS 14.5.
IP is of type connected to AXI4 Bus which is Burst capable, high throughput and Memory Mapped Interface.
All the tutorials currently available only explains the addition of an IP of type which can be connected over AXI4_lite bus.
I tried to create one of the kind previously mentioned, But i am not successful.
Is it necessary to add a BRAM and its controllers specially when we are creating this kind of  IP ??
Please check if these helps.
https://wiki.ittc.ku.edu/ittc/images/d/df/CustomIP.pdf
https://wiki.ittc.ku.edu/ittc/images/4/4a/Edk_customCores.pdf
https://www.youtube.com/playlist?list=PL6BCB2A81CBD665C5
Thanks,Vijay
Please check the EDK CTT. This is a old one but this is valid for XPS 14.5.
Chapter-6 would be relevant. Hope this helps.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/edk_ctt.pdf
Sikta
Thanks for replying.
But that was not useful.
I want a tutorial if any of them shows creating a custom IP which facilitates Burst Transaction support.
Check the attachment with the answer record below:
http://www.xilinx.com/support/answers/37425.html
It has a collection of Verilog template of AXI4 (full) master and AXI4 (full) slave. These should support burst transactions.
