SD Card + XilFATFS
           Can anybody guide be how to use XilFATFS lib for communication with Micro sd card.
           I want to open the .txt file in SD Card and write some data.
           I have added SPI core in EDK and respected pins are connected but I don't have any clue how to processed further with function in SDK. I'm all confused, read some other post which lead me to more confusion. So can i get help here please !!
Refer to chapter "LLibXil FFS (v2.2)" of Os and Libraries collection document.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/oslib_rm.pdf
Once you have configured the BSP as per the procedure mentioned above, you can refer to the following link for the APIs:
http://elm-chan.org/fsw/ff/00index_e.html
I would not find LLibXil FFS in my BSP lib. So how to get it
Right click on your BSP folder > Board Support Package Settings and enable the xilffs library as shown below
Yup I know it should be added from the path told by you. But the thing is that I can't find it over there. Instead of that I have xilfatfs lib. Are they one and the same
Which version of the tool are you using? and Which device?
XILFATFS provides read/write access to files stored on a Xilinx
System ACE compact flash or IBM microdrive device.
Check the chapter on LibXil FATFile System (FATFS) in the document below:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/oslib_rm.pdf
I have Spartan 6 board and I'm using EDK 14.7 . So is it possible for me write or read from SD card.
