makni
SD Card example design using standalone SDK project
I'm using a Zedboard and Vivado tool. I'm trying to load some image files(.bmp and .jpeg) onto the SD card of the Zedboard.
I'm using a Zynq-based SDK project and I want to know if it is possible to load/store image files from/to an SD card using standalone (bare-metal) OS?
Thanks in advance.
Mariem
trenz-al
you can do anything in bare metal, if you so wish.
So answer is YES.
sampatd
In addition, refer to chapter LibXil FFS in the following guide:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/oslib_rm.pdf
makni
Thank you for your reply.
I know taht the Zynq PS SD/SDIO peripheral controls communication with the ZedBoard SD Card.
I am trying to run a standalone project to open and read an image file (.jpeg) from the ZedBoard sd card as follow:
#include <stdio.h>
#include "xsdps.h"
#include "platform.h"
#include "xbasic_types.h"
#include "xparameters.h"
int main()
u8 RxBuffer[512*2];
int Status;
// SDIO Controller Test
static XSdPs ps7_sd_0;
XSdPs_Config * SdConfig_0;
SdConfig_0 = XSdPs_LookupConfig(XPAR_PS7_SD_0_DEVICE_ID); //XPAR_PS7_SD_0_BASEADDR
if (NULL == SdConfig_0) {
return XST_FAILURE;
Status = XSdPs_CfgInitialize(&ps7_sd_0, SdConfig_0, SdConfig_0->BaseAddress);
if (Status != XST_SUCCESS) {
print("Sd Config failed !\n\r");
return XST_FAILURE;
Status = XSdPs_SdCardInitialize(&ps7_sd_0);
print("Sd0 Initialization failed !\n\r");
return XST_FAILURE;
else {
print("Sd0 Initialization succeed !\n\r");
// read and write test
Status = XSdPs_ReadPolled(&ps7_sd_0,1, 1, RxBuffer);
print("Sd0 Read failed !\n\r");
return XST_FAILURE;
return 0;
The problem was in the Read function, it fails!
Could you help me please.
Thank you in advance.
makni
Can anyone help me please?
Thanks in advance.
embeddedcentric
Hi Makni,
You can find a detailed tutorial with the source code on how to use the SD card on a standalone SDK project targeting the Zynq7000 (Zedboard ) on this link http://embeddedcentric.com/data-logging-using-sd-cards/
Ali
yomna87
Hi embeddedcentric,
I tested your example but unfortunately does not working.
when I launch SDK there is no result.
I don't know what is the problem.
Please help me
thank you very match
Yomna
ericv
If you want to try another package, we make available a driver package for the Zynq (BSD license : meaning free) with working example on SDK for the ZedBoard.
code-time.com
vnagendra24
How to read float data types which are stored in a text file from the SD card?
ericv
If the SD card is formatted with a file system, e.g. FAT 32, you'll need a File system stack and then you can use the stack I/F to open & read the file contents.
If it is raw, then it's sector by sector you'll have to read.
In both  cases, once the data has been retrieved from the SD card, use sscanf() for example and that will convert your text (ASCII) floating point numbers in binary numbers
dhananjay201190
can we read .jpeg or .bmp files from sd card using application layer functions (f_read,f_write)?
mavi-mavi
I'm looking for an implementation example for SD card read/write with a uZED developement board. The link above looks like what I need, but the link is not working. Can anyone address me?
novec_16
Take a look at the post here
