SDIO controller capability for Zynq 7020
Hi Sir/Madam,
We are using Zynq xc7z020clg-484-1 chip.
Is that possible the SDIO controller support block length larger than 512 bytes ?
Here you will find the Xilinx errata:
http://www.xilinx.com/support/documentation/errata/en208.pdf
Copy paste from this errata:
<-snip->
SDIO
SD Capability Register Shows Wrong Max_Block_Length Value
Answer Record 47529
The SDIO controller supports a maximum block length of 512 bytes. The SDIO capability register indicates a max length of 4,096 bytes. The software driver must use the 512 byte length and ignore what is read from the capabilities register
<-snap->
Re: SDIO controller capability for Zynq 7020
I'm confused as to why you're asking something that is clearly specified in AR 47529.
If I were you, I'd assume the AR47529 were correct, but if that were a show stopper, I'd do some experimenting (which would very likely be a waste of time).
Mike
