46018
SDK 2015.2 - problem configuring xilisf to STM serial flash family over QSPI interface
I am working on Zynq-7000 with SDK 2015.2
My project works fine on 2013.X versions , using a bsp which includes the xilisf library, configured to PS-QSPI interface, and STM serial flash family.
When trying to make the same configurations on SDK 2015.2 (bsp OS version 5.1, xilisf 5.2, family - STM, interface - PS-QSPI) I get an error building the generated bsp:
" 'SpaMicWinDevices' undeclared (first use in this function) "
xilisf configuration view-
a short inspection of the error in the code, shows a strange behaviour:
The error, from xilisf.c (seems like the definition XPAR_XISF_INTERFACE_PSQSPI is not recognized. The error though is from a casted code) -
xilisf.h seems to recognize the XPAR_XISF_INTERFACE_PSQSPI decleration just fine -
and it also seems to be declared on xparameters.h -
I have tried the solution offered on this thread-
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-2015-2-fails-to-link-xilisf-5-2/m-p/650446#M37660
downloaded the attached xilisf.c to the xilisf_v5_2/src directory, but with no success.
Is this a known issue? Any solution?
thanks!
mark_xenint
Hi.
I'm getting exactly trhat with SDK2016.1.  Was there ever a solution to this? It seems to have been a problem over several versions of the tools.
... Do xilinx ever read these posts?...
Mark.
sjg69
Yep, just got the exact same thing with 2016.1 using a Zynq 7200 BSP with just the lwip and xilisf libraries included. Hey Xilinx, anyone there ?
pbastl
I had the same problem when I added more libraries SPI flash etc. The compilation was OK after removing them and leaving xillfs only.
smarell
Community Manager
Community Manager
Can you please share the workspace with me? I'll try to reproduce the issue at my end and take the necessary action.
Can you also update me on the flash you are targeting?
