jacob.varghese
SDK QSPI Flash interface Issue
I am using QSPI protocol to communicate with external Numonyx Flash(N25Q128).In XPS the QSPI IPcore is configurated but when I try to export SDK through PlanAhead the generated BSP platform is having SPI driver code not QSPI drivers. when I copy xilinx design example "xqspips_flash_polled_example.c" , I am getting error like #include "xqspips.h"  fatal error no such file or directory defined.
Can someone please help me out?I am struck with this issue for almost one week now..... :(
balkris
check this document
http://www.dejazzer.com/ee478/labs/lab6_mem_ext_spi.pdf
Thanks and Regards
Balkrishan
balkris
http://www.xilinx.com/support/documentation/application_notes/xapp951.pdf
Thanks and Regards
Balkrishan
jacob.varghese
Hey,
thank you for replying...
I have gone through the documents it says nothing about QSPI interface.I have attached the XPS core configuration,.xml file and .mss file. Please tell me what I am missing...
Processor : microblaze
Board        :  Kintex  KC705
pvenugo
Hi Jacob,
You might need to check the BSP folder in SDK project sources if the file is missing or generated.
The header file should be there inside and the directory of the file will be ..\SDK\SDK_Export\standalone_bsp_0\ps7_cortexa9_0\libsrc\qspips_v2_03_a\src.
I have attched the .h file for you.
Praveen
jacob.varghese
hello Praveen,
please note ......
pvenugo
Hi Jacob,
Yes, the header file is missing in your project. Try to add the attached xspips.h from the previous reply into your  project directory.
Praveen
sampatd
The SPI driver supports AXI QSPI IP as well. QSPIPS is the driver for PS QSPI on zynq. You are probably not using Zynq, so you need not worry about it.
In SDK, click on the documentation link next to "axi_quad_spi_0" and scroll to the end of the html file.
On the original issue, is it possible for you to archive the workspace and attach it? I will take a look.
jacob.varghese
So I tired including that header file but now it showing that  #include "xqspips_hw.h" is not defined.One workaround will be to include all related header file and c file, but my doubt is wont it be generated automatically by SDK when I include the XML file in which I have specified my mode is QSPI.
sampatd
Are you using Hard QSPI controller on Zynq?
If not, as posted above, SPI driver does support QSPI. You do not need the header "xqspips.h" - in fact are trying the wrong example "xqspips_flash_polled_example.c".
On the system.mss page, in your screenshot, click on examples next to "axi_quad_spi_0" and use them instead.
jacob.varghese
Hello samptad,
Many thanks...... I will try with this.... :)
ouyangli
I have the same problem, have you solved it?
