neowt
SDK debugs causes MMU section translation fault
I would like to share my observations of the below:
Problem:
  In SDK and launching an application to "Debug As -> Launch on Hardware (GDB)", SDK reports,
  "Unexpected error while launching program: Error while running ps7_init method.  Cannot read from target
   MMU section translation fault        "
Observation:
  This problem occurs when I let Zynq boots to Linux.  If I breaks into U-boot, I don't get the error and I can launch my debug application.
Solution:
  Break into U-boot if you wish to launch your own application for debugging.
My setup:
  Microzed in SD card boot mode, cascaded JTAG.
Neo
neowt
  The error is probably due to ARM MMU up and running and protected mode operations when Linux boots.
  I was making use of uboot to configure some low level peripherals so that my applications jump straight in to send data.  Sometimes I was slow at interrupting the boot process and the error occurred. Yeah, if you really do not need uboot, simply boot in jtag mode.
 As to the Bhaskarnallani's question, I guess you have to learn how to Linux device driver and apps.
Neo
achutha
Thanks for your effort in sharing your observation and solution.
This may help many to overcome the issue.
Achutha
aceachao
I have benefited greatly from your answer,Thank you very much.
but do you know why now?
aceachao
but i don't know why?
bhaskarnallani
Thanks man.
It helped to run my first simple IP on the Zynq706.
I would like to check how to run the same kind of application in linux and interact with my hardware IP.
Bhaskar
johnnymopo
I had the same problem.  I switched to not booting from SD and it seems to take care of it.  I'm a Zynq/ARM noob, but I just noticed this, and I'm sure its for a very good reason that I do not know.
neowt
Neo
sanjivgarg
I have the same question: currently we are designing our own zynq board for production; the hardware engineer wants to hardwire the zynq to boot from SD mode, but I am worried that then we wouldn't be able to debug from SDK;
has anyone else run into this? should we add a jumper to the board to switch from SD mode to JTAG mode?
pogany
I have the same bug, this post helped me a lot. many thanks
regards
Pogany
sanjivgarg
found the solution; create a simple helloworld BOOT.BIN file and write it to the SD card;
now you can debug from JTAG;
AlexD
A few years later.... I had a similar problem.
Check the installation of jumper JTAG BOOT MODE
AlexD
ali-dn
I had the same bug. I think,  problem is ddr access .
In [app_project_path]\src\lscript.ld all the section to memory mapping was set to ps7_ddr_0.
so I changed all of this part to ps7_ram_0 and so it worked.
