SDK repository not being picked up
Using Vivado/SDK 2018.3 on Win10
I have a custom board for which I need some modifications to LWIP2.02v1.2.  I've modified the sources for LWIP, put them in a repository at C:\XilinxProjects\PANOSETI\sw_repo, then point SDK to that directory:
Then I "regenerate BSP sources", etc, but the changes don't show up, the code is still that from the SDK install directory.
How can make SDK use my modified sources?
Thanks!
Rick
Re: SDK repository not being picked up
I believe I figured it out.  I hadn't copied all of the folders in the LWIP sources:
When I include data, doc, and examples, SDK sees the edited sources.
There needs to be two levels of hierarchy. See the wiki below, there is a section that covers your use case:
Adding custom BSP, Library, Drivers, or SW Apps to SDK:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841693/HSI+debugging+and+optimization+techniques
Can you try create a new BSP and check if your custom library is used?
Might be not picked up when using the regenerate bsp and you might need to create a new BSP, and use this on in your application (right click on your application, and under properties, switch the target bsp)
I tried making a new BSP- no help.
Here's the directory structure of my sw_repo
I point SDK to this directory like so:
There are changes in ethernet.c (among others) that are not being found.
I know I've done this successfully before, but maybe it was on a Win7 PC
Thanks for any help
Rick
