SREC Bootloader Speed
         I have used the SREC bootloader application by going through  the doc. and I was succesfull in doing so.
         My application loads properly and everything works fine but it takes enough time for that.
         It takes about 5 min to load, So can I reduce the time somewhere near 1 min ?? How??
There is a comment in the bootloader.c
/* Comment the following line, if you want a smaller and faster bootloader which will be silent */
#define VERBOSE
If you comment this line, it will be a bit faster.
--Hem
Are you loading the SREC file from ROM memory to the internal BRAM of MicroBlaze or into the DDR Memory..??
