07-12-2017 09:28 AM
Hi all,
What I'm trying to do:
What I've tried:
As you can tell I'm clearly new to this. If you can give me some advice or point me to some resources that would be great.
07-22-2017 11:39 PM
@aashwin Did you duplicate the block diagram carefully? do you have the two pieces in the bottom center of the image you show? (bram controller and blk mem gen)
07-23-2017 02:28 AM
I should have added that this is now solved.
I was in the project for the 'neo_pixel' ip block, the problem was the block mem was not in the project. Simply went to IP catalog, inserted the block memory, used the instantiation template. After this all was well.
Thanks for the reply.
