nadaumtimuj
Slow JTAG read
What is the optimum frequency for AXI master-slave when the system clock frequency is 250 MHz and JTAG frequency is 15 MHz? Thanks..
I currently set it to a clock_out of 200 MHz which seems to be very slow when I do read write. I am using KCU040 board and using a micro USB cable that connects to Digilent USB JTAG module on the board.
Tags (2)
drjohnsmith
The JTAG and the AXI are not directly related
The JTAG can run at say 1 MHz or 10 MHz, the AXi does not care.
JTAG is used for debug and configuration, not real time access.
  It runs over a serial link, similar in many ways to SPI,
        https://www.xjtag.com/about-jtag/design-for-test-guidelines/
nadaumtimuj
@drjohnsmith Thanks! I am using JTAG for read/ write through MATLAB. I have implemented this design here:
Access FPGA External Memory Using MATLAB as AXI Master - MATLAB & Simulink Example (mathworks.com)
Instead of external memory, I am just writing to slave register.
So you are saying whatever I am getting is my bottleneck? I can read 10k samples in 20 sec with a 15 MHz JTAG connection.
drjohnsmith
thats not bad speed for  a serial link,
   I'm amazed your getting 15 MHz reliably
       JTAG is normally a few MHz, they must have made that board for speed.
dump Matalb might speed things up somewhat
  but thats a different story
nadaumtimuj
Not sure if I am getting truly 15 MHz. But both Matlab and Vivado shows that my connection speed is 15MHz. All I know is I can perform 10k read operations (10k MATLAB readmemory function)  in 20 sec. Thanks anyway!
