08-21-2017 06:55 AM
I'm using Vivado 2016.2 and I'm trying to create a project for XC7Z045-2FFG900I.
For the industrial temperature range vivado made me choise only the -2L speed grande insted of -2.
What I got wrong?
Thanks in advance
Filippo
08-21-2017 07:26 AM
The -2L (the L here stands for low power) is guaranteed to have the -2 performance even at lower power.
I presume the reason for the industrial temperature range is to make sure that the device still performs as expected under harsh conditions.
Hope this helps,
Herbert
08-29-2017 04:05 AM
With 7-series, you can select the commercial grade (as per AR#38221)
Only the operating range will change between the commercial and the industrial grade.
Florent
