Spi as slave does not work in FPGA. Zybo Board
Hi, i am trying to build spi as slave in Zybo board. using the example program Slave_intr_example. the mosi pin does not read anything. miso sends data. and clock works fine. the program does not come out of while(Transferprogress==True) and even in debug mode the read buffer will be empty.
Re: Spi as slave does not work in FPGA. Zybo Board
Hi @rahulgujaran3,
Could you check if you PS SPI controller is configured as slave device appropriately?
Because MISO works at your end and sending data to FLASH.
Praveen
i am using quad spi  IP as slave. Ps slave is not used.
