bla32
Streaming audio file from ram through ac97
hi all.  i'm trying to stream an audio file from ram into my ac97 codec but i don't know how i should approach this.  any hints or tips on how i should get started?  also, does anyone know what type of data the ac97 takes in?  i doubt it'll take in .wav files.  i'm considering converting the .wav file into raw data using matlab and using the xmd to write it to ram.  any suggests will be of much help.  thanks.
-alaire
eteam00
Professor
Professor
Are you asking for a referral to a design service for hire?
-- Bob Elkind
SIGNATURE:
Summary:
bla32
no i'm working on a project in which i use the keyboard to trigger an output of a sound file through the ac97 of the virtex II pro development board.  so far i've instantiated the ac97 codec provided by
http://embedded.olin.edu/xilinx_docs/projects/audio-v2p.php
it was an ise project so i had to import the peripheral into edk and all it does now is output a buzzing noise.
thanks.
