Supported LPDDR2 devices
Hi all!
Just a quick survey before we commit our design to PCB: Does anyone have experience with LPDDR2 devices other than the two pre-selectable in XPS (MT42L64M32D1KL-25 (2 Gbit) and MT42L128M32D1KL-25 (4 Gbit). Both are single die, single channel, 1 rank per channel devices. The device we originally intended to use was a lot smaller, MT42L16M32D1AC-25 (512 Mbit), also a single die, single channel, 1 rank per channel device. I assumed it would be OK and altered the settings in XPS accordingly, but now the SW guys are concerned about space so they want to stick on the MT42L32M32D2AC-25 (1 Gbit). This is a dual die, single channel, 1 rank per channel device. Does anyone see any problems with that?
BTW, could someone explain the term “rank” in this context to a BDU (Brain Dead User)? It says in the TRM “Maximum Ranks” = 1, but the term is unfamiliar to me. Not that I think it matters, all devices above are single rank.
Thanks!
/Lars
I see no issues with that part.
A rank roughly translates to 'number of chip-selects.'  Please take a look at the Micron datasheet "U80M_4Gb_mobile_lpddr2_s4" (find part number MT42L256M32D2LG-25 WT).  Figures 4 to 10 will show various rank and channel configurations.  Any configuration that matches the I/O of figure 4 should be Zynq-compatible.
You can select one  among the available parts that matches your desired part as Base part and vary timing parameters and address signals to achieve your required LPDDR2 part.
MPMC/MIG has no specific meaning other than the industry standard, it is just set of DDR chips connected to a single CS.
Please refer wiki, if you are still unclear let us know.
http://en.wikipedia.org/wiki/Memory_rank
Hope this helps
Vanitha.
Thanks!
That cleard things up for me. I hope to be able to post back in a few weeks to confimt that it worked.
/Lars
