Systemverilog Design of AXI4
I have a project coming up in 2 weeks. So, I'm looking for AXI4 design in SystemVerilog to verify and emulate. It would be very helpful if anyone in this forum could provide me a design.
Have you considered this AXI-lite design?
Dan
Ya, I was looking at AXI lite as well, but could not find a proper design. This document is very useful, thank you!
Do you have a design code of AXI lite?
@srixilinx,
Do I have a design that uses AXI lite?  Yes.  The link I gave you above links to it liberally.  In case you haven't found it, you can check it out here.
Dan
@srixilinx,
It should be linked throughout that article.  (Yes, that was an AXI-lite article.)  If you don't see it, you can find the code here.
Dan
@dgisselq  Thank you for your quick response! I will go through the code
