joancab
TTC interrupt has no ID
I'm using a TTC to trigger some software process. I based myself on the example in xttcps_intr_example.c.
For some time it worked fine, now for some reason sw hangs after a while, apparently cause by an interrupt.
I found there is no XPAR_XTTCPS_0_INTR defined in xparameters.h (also nothing similar)
How can I make the TTC to have interrupts again?
Tags (2)
joancab
It is defined in xparameters_ps.h !
joancab
