I have Vivado 2018.3. In BD for existing design I replaced the DMA Bridge for PCIe with AXI Bridge for PCIe IP. Using the same AXI Interconnect I re-assigned all AXI related connections manually. Then I found that I Address Editor the fields Offset Address, Range and High Address are blanked, and not editable. Is it a tool bug?
What is a work around? I prefer not to delete and add the AXI Interconnect again. Too messy.
I attached the Address Editor view.
Thank you.
