Anonymous
Not applicable
Timer/Counter Core
I'm planning to use a Timer/Counter core provided in EDK, in order to know how much time does my C code need to be executed.
first: I would like to know if the idea is correct
second: where can I find the Timer Core driver
Thank you
golson
Yes, I this has been done before using the XPS_TIMER.
Example
http://forums.xilinx.com/t5/EDK-and-Platform-Studio/Using-The-Timer-counter-peripheral/m-p/42429
http://forums.xilinx.com/t5/Embedded-Processing/XPS-Timer/m-p/46649
You can search the forums for example TIMER and get many posts.
As far as driver goes.  The Driver is brought into your design when you create the software project
and the project creates the board support packages and libraries automatically.
golson
Example
