12-22-2015 03:07 AM
I'm running a baremetal application which uses the ARM global timer on Zynq 706. When run with a custom IP and zynq connected, I get a timer overhead of 50 cycles and while I run MIG and zynq connected, I get a timer overhead of 300 cycles. Since the timer overhead (time to just start and stop the timer) has nothing to do with FPGA hardware why is there a variation in the overhead? Please advise. Thanks.
I'm using Vivado and SDK 2015.2.
Best Regards,
Nitin.
12-22-2015 04:08 AM
12-22-2015 04:08 AM
12-30-2015 12:57 AM
The problem was solved after a change to the linker script.
Thanks and Regards,
Nitin.
