Timer Overhead on Zynq Baremetal
I'm running a baremetal application which uses the ARM global timer on Zynq 706. When run with a custom IP and zynq connected, I get a timer overhead of 50 cycles and while I run MIG and zynq connected, I get a timer overhead of 300 cycles. Since the timer overhead (time to just start and stop the timer) has nothing to do with FPGA hardware why is there a variation in the overhead?  Please advise. Thanks.
I'm using Vivado and SDK 2015.2.
Best Regards,
Nitin.
where is your code located??
if in MIG RAM it is slower
The problem was solved after a change to the linker script.
Thanks and Regards,
Nitin.
