Transfer a variable stream to memory
Hi , i need to transfer variable data from stream to memory, should i use an AXI DMA?
I have 4 stream to transfer
Tags (2)
Yes you can use AXI DMA.
Please check PG021 for further details.
You could also find some AXI DMA example on this Github_repo.
Best regards,
Abdallah
@mrbietola
Here's a thread that extensively discussed the PS-PL interface if you mean PS DDR. Might be worth a look even if you wanted BRAM.
PS-PL interface discussion
Jerry
i don't have a Zynq, i need to store data coming from an H264 compressor to memory
Voyager
Voyager
I recently found a number of limitations of the DMA IP core. I solved it with a piece of HLS and an AXI master port interfacing the memory AXI slave. Not difficult and you have more control. My suggestion is that you implement it in HLS, it's an AXI-stream on one side, AXI master on the other, and some logic and buffer in between.
Have you tried upgrading the operating system of your spirit level?
@joancab that seems interesting,
since i'm new to HLS, can you point me to any reference design for this kind of application?
Voyager
Voyager
I'm not aware of any ref design specific for that. I got everything from UG902 basically. the key thing is configuring the ports, besides that I think it's a simple thing: receive via stream and save sequentially. You may want to read Tlast to end the transfer and reset the write pointer, etc.
Voyager
Voyager
With HLS you can have a smarter solution, first of all you don't need software to set it up, second you can have, for example, the transfer size at the start of the stream so the IP knows when to stop. Even possible for the IP to stop if, for example, no data for N clocks. I used the DMA blocks a lot, but they are limited. I read somewhere if they receive data before set up, they hang.
