Two questions about PL and PS VCCO power rail of zynq ultrascale+ MPSOC
I have two questions about PL and PS VCCO power rail of zynq ultrascale+ MPSOC:
(1) Can the PL and PS VCCO_[bank] of zynq ultrascale+ MPSOC share a common power rail in a board?
(2) Can the PL / PS VCCO_[bank] share the power rail with other chips in a board?
Thanks!
@luckzzylb Please follow UG583. XTP427 is going to have this (VCCO_PSIO) fixed in the next revision (Already aware  of this issue)
As mentioned above, just make sure the voltage rails clubbed meet the data sheet requirements for voltage and tolerance.
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
If they are the same voltage, yes, and yes.
Please check you stay within the recommended ranges for all supplies, at all times.
In some safety critical applications, sharing supplies is a common failure mechanism, and is not done.  Otherwise, if anything requires a particular voltage, and the noise and variations are within specifications, a common supply rail is just fine.
Austin Lesea
Principal Engineer
Xilinx San Jose
@austin, thanks for your help
According to ug583 chapter4Power Supply Consolidation Solutions for Zynq UltraScale+ MPSoCs:Figure 4-1.png
The dashed lines in figure 4-1 means the VCCO_PSIO and VCCO can share a common power rail. So, in our board, we have a design as follows:
However, in the xtp427  "ultrascale plus schematic review checklist" , it says “the VCCO_PSIO cannot be combined with any other rails”:
Now , we are confused.  Which one is correct?  The ug583 or xtp427?
Good catch!
I will check with the designers.
Austin Lesea
Principal Engineer
Xilinx San Jose
@austin, so is there the mistake in xtp427?
- Giri
