alangford
Typo in Zynq-7000 Technical Reference Manual (UG585) - GTX channel site numbers
I believe I've found a typo in the latest version of the Zynq-7000 Technical Reference Manual (UG585 v1.11 September 27, 2016)
Im targeting the following device: XC7045FFG676-2
The GTXE2 channel sites for bank 112 listed in the TRM for this device (p635 figure 21-5) do not agree with the tool (Vivado 2017.2)
For example, MGTX0_112 is listed in the TRM as site GTXE2_CHANNEL_X0Y4
    In actual fact (as per the tool), the site for this channel is  GTXE2_CHANNEL_X0Y12
The same is true for the other 3 GTX channels in this bank.
florentw
Hi @alangford,
Thank you for reporting this error in the UG585. This should be rectified in a future version of the document.
Kind Regards,
Florent
Florent
florentw
Hi @alangford,
Kind Regards,
Florent
Florent
