NasimS
UART interface is so slow
Hello all,
I am using the PMOD interface of ZCU111 to control a peripheral through UART communication. The data that host/ZCU111 is receiving can be: 1) negative or positive 2) 4 or 5 bytes (depends on the environmental temperature).
The issue is that when in the C code/SDK, the number of bytes is being set to 4 bytes, no issue is being observed but upon changing the number of the bytes to 5, the communication is becoming very slow such that in a "for loop" with 50 iterations, each iteration takes a few min while in 4-byte case, all 50 iterations are being executed in several seconds.
I was wondering whether you could provide any feedback about the possible root cause of the issue.
Sincerely,
Nasim
maps-mpls
Mentor
Mentor
You will need to post more details.
1.  Which processor are you using?
2.  What driver are you using?
3.  Are you interrupt driven?
4.  Post your for loop.
*** Destination: Rapid design and development cycles ***
