san_2190
UART multiple bytes receive problem using microblaze -kc705 board
     Im sending a total of 133 bytes from the host pc's virtual com port to the UART on KC705 board . The uart ipcore is connected to the microblaze processor. The uart receives only 29 bytes out of which only the first 19 bytes are accurate and remaining 10 bytes are corrupted. I hv wriiten the host code on pc using windows programming to send 133 bytes of data. All 133 bytes are sent from the pc's com port. what could be the problem with uart ?
San
htsvn
Which example source code are you using to transfer multiple bytes?
As i understand the uartlite polled example code, the buffer size is set to 16 bytes.
--Hem
san_2190
Hi Hem,
              Im not using the polling method. Im using interrupt to receive data on uart. The example source code is xuartlite_intr_example.c .... Moreover I have increased the test buffer size to 133.
San.
tessitd
Sounds like an overflow problem, what flow control are you using on the UART port?  If "none" this could be why you are missing data.
TomT...
san_2190
Hi TomT,
                 The flow control option seems to appear only on the port settings for the PC's com port . And it is "NONE". I have not included the flow control option in both the windows host code and processor code. What should the flow control option be set to ??
-San
