ULPI register access on Zynq MP+
Is it possible to read/write ULPI registers on a Zynq MPSoC?
Let's say I for example would like to set pull ups on a USB3320 PHY.
I saw that it seemed possible when using the AXI USB 2.0 IP (usb):
But nothing similar when using the built in Zynq MP USB driver (usbpsu).
Vivado/XSDK 2018.3.
Erasmus Cedernaes
Saab
Re: ULPI register access on Zynq MP+
I solved this by looking in the example code ritakur provided as well as the UG1087 where there is a register called GUSB2PHYACC_ULPI in USB3_XHCI which is used for accessing ULPI registers. Setting the bit REGWR indicates that it's a write instead of a read. The data to write shall be placed in REGDATA.
yes, you can access USB PHY register as USB3320 used on ZCU102.
I attached the C code I used for PS USB0.
it's a Linux app. Command in Linux as follows
USB0:
./phy_dump.elf 0
USB1:
./phy_dump.elf 1
The example code only seems to read ULPI-registers. Is it possible to also write to them?
Alternatively, is there any documentation that covers the meaning of the bits in the GUSB2PHYACC_ULPI register and how to interact with it?
Erasmus Cedernaes
