USB Interface for Zynq SoC
Hello everyone
I started a few weeks ago working on the MicroZed board, equipped with a ZYNQ SoC, and I have to receive datas from the USB port of the board (in the end I'll have to catch a video stream from the USB). I'm new in the field of USB interface, and xilinx tools, so I have a lot of trouble!
I made some research, I found a lot of code (like the xusbps, since I'm coding in C), but I don't know how to use it, and there I'm a little bit lost! Does someone has an idea on how to use the USB port? The only posts I found on forums seems to be written by experts, for experts :p
Thanks for your help!
Thomas
Hi ,
Please  refer below link for verifying usb peripheral mode, The bare metal driver will only support peripheral mode and it will not host & otg mode.
http://www.wiki.xilinx.com/Zynq+Standalone+USB+device+driver
You can find the bare metal USB applications in SDK installed path : C:\Xilinx\SDK\2017.3\data\embeddedsw\XilinxProcessorIPLib\drivers\usbpsu_v1_3\examples
Please create an empty application with SDK and copy this files (xusbpsu_ch9_storage.c , xusbpsu_ch9_storage.h , xusbpsu_ch9.c , xusbpsu_ch9.h , xusbpsu_class_storage.c , xusbpsu_class_storage.h , xusbpsu_intr_example.c)  and don’t copy *dfu files and build.
For your reference to create an application using SDK:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/SDK_Doc/tasks/sdk_t_project_creation_zynq_fsbl.htm
Please let me know in case if you face any issues.
Thanks & regards
Aravind
Hi ,
Thanks & regards
Aravind
Hello
Thanks a lot for your help!
I did what you told me, I created a new empty project, copied the files, but I have some errors with the defines from the "xparameters.h" header file. In fact in the source code I copied I find a lot of definitions not written in the xparameters.h
Do you know how to fix that? I don't feel like I should put some random values for the variables like "DEVICE_ID" or whatever
PS: I'm using the usbpsu v1_2, since I don't have the v1_3 in my SDK install. A suppose there is not a lot of difference between these 2 versions for my purpose... Feel free to tell me if I absolutely need the v1_3
Yes you are right usbpsu v1_2 is having some build errors and usbpsu v1_3 is working fine . more ever for zynq-7000 dont use usbpsu_v3 drivers path.
Please build the files from this path:C:\Xilinx\SDK\2017.3\data\embeddedsw\XilinxProcessorIPLib\drivers\usbps_v2_4\examples path for zynq platform.
Let me know if you face any issues.
Thanks & regards
Aravind
 I'm having a look at the usbps v2_4 code, and something is weird:
I'm stuck in a while loop, in the xusbps_intr_example.c code:
line 312:
while(NumReceivedFrames < 1){
          /*NOP*/
And nowhere in the project the NumReceivedFrame's value is modified.
Then, I don't really understand what this code is supposed to do, I mean, I build, compile and execute the code, and nothing happens, even when I plug in a USB key. (Sorry if I have troubles to understand, I'm all learning by myself with this project)
Let  me know is it worked or not, It should work if you follow my previous steps which i mentioned in same thread.
Thanks & regards
Aravind
