assaf_malki
Uart 16550 Fifo
Hey guys.
Uart 16550 core comes with Rx and Tx fifos with the size of 16 bytes each.
I need somehow to change it to 256 bytes.
Is there an easy way to do it before I dive into xilinx IP core?
Thanks a lot.
Assaf.
mdenzin2
Did yo uever resolve this?  I am encountering the same problem.
trilok_4
Even I'm facing the same Problem, I need depth of 2048 Bytes Thank you Trilok
pvenugo
You may have to edit the RTL of the IP core for more than 16 bytes.
Praveen
